Hondata installation question, Did search
I have a quick question abou the installation of the S100 system. It says that I need to solder it to the CN2 port. I am using an ODB 1 PR4 ecu on my 96 LS the CN2 port on the PR4 ECU, has 5 little ports, and the Hondata s100 has 4 plugs on the clip. My question is do I just install the Hondata all they way to the left leaving the 5 port on the CN2 empty. I have a pic of the port on the PR4 ecu it is a bad pic, you can kind of make it out. The PR4 ecu should work with my setup right? I was told it would.
Setup:
PR4 ODB1 ECU
96 LS motor
ODB 2 to ODB1 conversoin harness
98 civic dx wiring harness
Here is the pic
[Modified by sydag5, 12:08 AM 2/18/2003]
Setup:
PR4 ODB1 ECU
96 LS motor
Here is the pic
