Hondata installation question, Did search
Old Feb 17, 2003 | 03:03 PM
sydag5's Avatar
Default Hondata installation question, Did search
I have a quick question abou the installation of the S100 system. It says that I need to solder it to the CN2 port. I am using an ODB 1 PR4 ecu on my 96 LS the CN2 port on the PR4 ECU, has 5 little ports, and the Hondata s100 has 4 plugs on the clip. My question is do I just install the Hondata all they way to the left leaving the 5 port on the CN2 empty. I have a pic of the port on the PR4 ecu it is a bad pic, you can kind of make it out. The PR4 ecu should work with my setup right? I was told it would.
Setup:
PR4 ODB1 ECU
96 LS motor
ODB 2 to ODB1 conversoin harness
98 civic dx wiring harness
Here is the pic
[Modified by sydag5, 12:08 AM 2/18/2003]
Old Feb 17, 2003 | 03:15 PM
XES's Avatar
XES
Default Re: Hondata installation question, Did search (sydag5)
Solder it in area 1-4. Leave 5 blank. The plastic side of the 4pin socket should be closest to the side of the ecu.
Old Feb 17, 2003 | 03:17 PM
sydag5's Avatar
Default Re: Hondata installation question, Did search (XES)
Thanks
tub_sephiroth
Nov 18, 2004 10:27 PM
PreludePhill
Oct 15, 2004 05:40 PM
BLaCk-S
Mar 18, 2004 09:10 AM
