What diameter low profile fan did you guys get for your Civic radiator?
Old Feb 17, 2003 | 11:32 AM
Smashback's Avatar
Default What diameter low profile fan did you guys get for your Civic radiator?
12" I assume?
Old Feb 17, 2003 | 11:53 AM
Midwestrider's Avatar
Default Re: What diameter low profile fan did you guys get for your Civic radiator? (Hatchblack)
Yah 12"
Goto Jegs.com and look for the Proform 12" fan.
I got that info from CzanSOHC.. I take you are looking for a pusher fan?
Old Feb 17, 2003 | 12:05 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: What diameter low profile fan did you guys get for your Civic radiator? (Midwestrider)
mine is a 12 inch, i likess.. heres some pics incase anyone was wonderin what they look like.
[Modified by SIXTYdashONE, 9:06 PM 2/17/2003]
Old Feb 17, 2003 | 12:06 PM
9krpm's Avatar
From: see my earring from a MILE, bling bling, Va, USA
Default Re: What diameter low profile fan did you guys get for your Civic radiator? (SIXTYdashONE)
ive got a 14" pep boys flex o lite knock off. Paid like 60 bucks for it. Good ****.
Old Feb 17, 2003 | 12:07 PM
ekb18c's Avatar
I gotta double check but I think I used a 14in" on a stock rad.
edit- Yup, if Ron is a 12" then I used a 14".
I decided with a 14 because it fit the rad. bettter.
Damm Ron! No matter what, Mine's is always bigger.
[Modified by ekb18c, 1:09 PM 2/17/2003]
Old Feb 17, 2003 | 12:22 PM
Smashback's Avatar
Default Re: What diameter low profile fan did you guys get for your Civic radiator? (ekb18c)
Sweet, thanks guys. I ordered a 12" SPAL puller for like $71. 830 CFM or something like that.
I couldn't put a pusher on there because of the oil cooler...and the SPAL seems to be the thinnest of them all, like 2.1" or something. Most are 2.25" or more from what I've seen.
Old Feb 17, 2003 | 12:54 PM
HT's Biggest Loser
, this guy..
EDIT: to Colins coment tho, the 14 inch doesfit a little beter, you can see from the picture that theres more room to fit it. When i was purchasing one, the next size tey had was a 15 inch, and i thought that might be too big, so i stuck with the 12, oh wells
[Modified by SIXTYdashONE, 9:55 PM 2/17/2003]
Old Feb 17, 2003 | 01:59 PM
B18EG6's Avatar
ehh i dont know how thin you woul call this...or if its what you are looking for...but heres my fan
Old Feb 17, 2003 | 02:40 PM
LSiTurbo's Avatar
i run a 10" but 10 or 12 worls great. you can get a regualr flex a lite for like $75
Old Feb 17, 2003 | 03:00 PM
CRX SiR T's Avatar
Default Re: What diameter low profile fan did you guys get for your Civic radiator? (LSiTurbo)
I'm running the 12" Summit fan. It's 3" thick, but it's 900 CFM and is adjustable if you want a pusher or puller type setup
is no1 running the overflow line?? i noticed in both those pics the line wasn't hooked up. i ask b/c mine keeps on kinking
Old Feb 17, 2003 | 03:20 PM
HT's Biggest Loser
Default Re: What diameter low profile fan did you guys get for your Civic radiator? (CRX SiR T)
mine just wasnt in the pic at the time, heres another pic
Old Feb 17, 2003 | 05:12 PM
Foozball26's Avatar
chris how big is the oil cooler.
you should order 2 fans and get the stockers out of there.
dunno if you're keeping a/c or not but if you are make the radiator fan a puller and the a/c a pusher then mount the oil cooler on the radiator.
I got my slim lines from autozone, they are like $60 and are like 2"
turboDeznutz
Apr 24, 2007 09:20 AM
b18bturbo
Jun 23, 2006 06:15 AM
iCe_2x
Mar 16, 2006 02:17 PM
Unjockable
Mar 11, 2005 01:07 PM
DubyaAye
Apr 16, 2004 12:59 PM
