P74 ecu auto or manual/hondata question
Old Feb 17, 2003 | 10:50 AM
LudEcrous's Avatar
Default P74 ecu auto or manual/hondata question
I have a p74 Integra GS/LS/RS ecu, and i want to know how to tell if it's a 5-speed or auto ecu. There are no stickers on it. It's hooked up to my hondata, that's in my prelude si-t. The problem i'm having is that i'm hitting some kind of revlimit at 6500 rpms. i thought we set the revlimit up to 7000 when setting up the hondata. Is there a way to tell for sure that the ecu i have is a 5-speed one? or would it matter?
Old Feb 17, 2003 | 12:46 PM
inspyral's Avatar
Default Re: P74 ecu auto or manual/hondata question (LudEcrous)
here you go:
Old Feb 17, 2003 | 12:52 PM
inspyral's Avatar
Default Re: P74 ecu auto or manual/hondata question (inspyral)
May bad, looks like P74s are laid out differently:
Old Feb 17, 2003 | 06:11 PM
LudEcrous's Avatar
thanks for the pic, but what am i looking for on the p74 ecu?
Old Feb 18, 2003 | 07:31 AM
Doodoo's Avatar
At the bottom right corner, look below the socket. These are labeled RP. RP17 should be empty. That designates it 5 speed.
Old Feb 18, 2003 | 08:10 AM
LudEcrous's Avatar
Default Re: P74 ecu auto or manual/hondata question (Doodoo)
Thanks for the info!
Old Feb 20, 2003 | 10:47 PM
swrdply400mrelay's Avatar
here you go:
So all you do is cut off those two black boxes and you've converted your ECU into a manual?
Old Apr 10, 2003 | 03:48 PM
AzN_Flava's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">here you go:
so I unsolder those 2 pieces, and my 94 ls auto ecu is a manual ecu?
Old Apr 10, 2003 | 03:55 PM
Sonny's Avatar
No, don't do that. There is a resistor that gets cut. You don't need to take those transistors out.
Old Apr 13, 2003 | 07:15 PM
AzN_Flava's Avatar
Default Re: (Sonny)
what resistor do i cut then?
Old Apr 15, 2003 | 03:54 PM
AzN_Flava's Avatar
Default Re: (AzN_Flava)
up up up
balbowskie
Aug 24, 2012 03:56 AM
G_seven
Acura TSX
May 6, 2008 07:18 AM
teg01type-r
Jan 3, 2007 03:20 AM
redlineintegra
Mar 8, 2004 06:31 PM
accordfreak
Oct 31, 2002 07:21 AM
