what should i expect? sohc+vtec+turbo=????
i finiched the car(90 hatch) in november , car runs fine,
sohc, turbo, 2 1/2 in. exhaust, afc, fmu,
any times and mph??????please!
The weight of the car is very critical. As well with the gearing setup (gears, flywheel, overall tire diameter, weight of the tire, etc.)I've seen guys with '88 HF Crx with only a mini me breakn into the 13's .
I maybe in the process of doing this to my CRX, a complete pictorial article for everyone to see if it possible to break 13's under $1000 all-motor SOHC VTEC or Non-Vtec, don't know yet.
damn...man...
well im running 6lbs. of boost
street slicks on the new si wheels,
internals are stock...act clutch,
starion IC., door panels, rear panels will be stripped!
questions like this are just stupid.. their are way to many factors in racing to really know what the car is capable of. Driver/track conditions/how well the car is tuned/traction/weight of car. etc etc. The car could easily be a 13 sec car if not faster.
I hit 13.5 on both my mini-me turbo setups.
Jeff
Jeff
If you put on a few APC stickers, neon, and nawwwws you should be in the low 8's.
That's slow... you should look into getting an SR20DET swap and some Spoonz rimz, y0!
you don't have anything to say, shut the FK up.
then for your time, I think with striped car, good ruber and the rest is all about driving abillity, you should hit the 13 sec or not too far.
allmotorEG-SI
Sep 30, 2001 12:43 AM
