Turbo GSR fuel cut off??
Old Feb 17, 2003 | 10:17 AM
Mighty Mintos's Avatar
Default Turbo GSR fuel cut off??
i have a 95 GSR with a max rev turbo kit with hondata s200 with boost. i am boosting 5 psi and at 7000 rpm the fuel cuts off. during the dyno session, the tuner disabled all the sensors, ie knock, o2, rev limiter,boost etc, and still the fuel cut off. has anybody ever ran into this? does anyone know why the fuel gets cut off?
Old Feb 17, 2003 | 10:28 AM
madman604's Avatar
Default Re: Turbo GSR fuel cut off?? (F20bcivic)
doesn't the s200 have rev limit removal?
Old Feb 18, 2003 | 12:20 PM
Default Re: Turbo GSR fuel cut off?? (Turbo E)
we removed all rev limiters. the problem is a fuel cut off, but i dont know why it cuts off.
Old Feb 18, 2003 | 12:27 PM
B20-T's Avatar
do u have a msd ignition system?
Old Feb 18, 2003 | 12:48 PM
Default Re: Turbo GSR fuel cut off?? (B20TURB0)
nope. i have no problems with ignition at all. the fuel just seems to cut off.
Old Feb 18, 2003 | 12:57 PM
B20-T's Avatar
what kinda ecu are u running?
Old Feb 18, 2003 | 01:31 PM
p72 with hondata. its a stock integra gsr 4 door with turbo. still dont know what the fuel cut off is.
Old Feb 18, 2003 | 01:33 PM
DIRep972's Avatar
Smarter than you
u did set the map for a vtec car in the settings right?
Old Feb 18, 2003 | 01:46 PM
madman604's Avatar
Default Re: Turbo GSR fuel cut off?? (DIRep)
um did you guys upgrade the fuel pump?
Old Feb 18, 2003 | 04:05 PM
the fuel pump is still stock, but i dont think the fuel pump needs to be upgraded.
Old Feb 18, 2003 | 06:11 PM
B20-T's Avatar
tell me what do u have for your fuel system..
Old Feb 18, 2003 | 07:44 PM
rc 440 injector and a fpr.
Old Feb 18, 2003 | 08:11 PM
b16ahybrid's Avatar
just out of curiosity whats your air/fuel ratio at 7k rpm?
Reason i ask is because if your running really rich the car will feel like it hit the rev limiter. That happend to me when i upgraded my turbo.
Em1Rookie
Sep 30, 2006 02:16 PM
FmXRider991
Mar 16, 2005 06:19 PM
Jcup315
Mar 6, 2005 03:05 PM
92civiclsb18a
Jul 3, 2004 02:16 AM
jwcardy
Apr 4, 2004 02:53 PM
