Is this bolt ok to fill up the trans ?
Old Feb 16, 2003 | 09:28 PM
RCautoworks's Avatar
Default Is this bolt ok to fill up the trans ?
Me and my friend got into a little discussion, what do you think ?
Old Feb 16, 2003 | 09:33 PM
JCracer723's Avatar
Default Re: Is this bolt ok to fill up the trans ? (90blackcrx)
is it ok to fill up the trans?????
if u are lookin for the bolt where u drop the oil in the transmission . NO thats not it its on the rear side bottom , close to where u bolt the right axle use a 17 mm socket if im not mistaken ...
Old Feb 16, 2003 | 09:35 PM
the DR.'s Avatar
wow nice tranny... if the bolt actually has a hole going into the inside of the tranny, then i dont see why not.. just make sure you open then actual fill bolt to make sure the level is correct
Old Feb 16, 2003 | 10:08 PM
Default Re: Is this bolt ok to fill up the trans ? (SlicedBread)
I forgot to mention, the main reason I fill it up from there is because the filler bolt runs into the back cross member thing, there is no room to take it off. That is why I fill it up from there. Yes it goes threw all the way, I have filled it up from there before and its fine, he just said its not a good idea.
Old Feb 16, 2003 | 10:33 PM
escocrx's Avatar
well only one problem with that. to make an accurate fill you need to use the assigned bolt on the side. or else how will u know the amount??
its supposed to run out when its full. how are u gonna tell? jus my opinion.
Old Feb 16, 2003 | 10:40 PM
Default Re: Is this bolt ok to fill up the trans ? (escocrx)
Yeah thats what he said, plus I was thinking if that bolt was under the fill hole spot then it could be off alittle. But it looks like its about the same height as the fill hole.
Old Feb 16, 2003 | 10:46 PM
vulcandan's Avatar
This is a bit off topic, but I'm dying to know. What the hell did you use to clean that case? It's clean as hell!!!!
Old Feb 16, 2003 | 11:16 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: Is this bolt ok to fill up the trans ? (vulcandan)
i have a 200 degree steam cleaner at work, and i could get it cast alum. bare, if i sit on it for a few mins.. but all he did was paint it.. looks good if your into flash.. i aint got **** on my YS1 LSD.. yeah, im a JDM *****.. lol
aznromeo4u
Feb 24, 2015 02:52 PM
doom26464
Jun 18, 2008 07:10 PM
shai x boi racer
Jan 25, 2005 06:45 PM
asubennett
Aug 21, 2003 05:14 PM
gumbybum
Jan 28, 2003 09:40 PM
