auto x
aaaahhh I believe the cones are laying down on purpose and pointing in the direction that he is supposed to be running. Well that's the way they do it for autoX around here.
beefpigs is right and if threatcon ever got out of his room and raced, he would know that's how an auto cross track is set up. any ideas on how to stop the body roll in that picture? and threatcon the members corner is no more, thought you knew that!
[Modified by au-gsr, 9:06 AM 2/17/2003]
ITR rear sway bar will take some of that roll out of your body
Its a very cheap and effective mod!
First thing you should do (with the BSQ kit). Cheap and the best suspension mod you can do.
True but if he is running in the stock class that will bump him to street prepared or STS.
post this in members corner, doesnt belong here.
My next whoopin session is in in 2 weeks.
[Modified by 5-SpeedFreak, 11:19 AM 2/17/2003]
Mostly honor system, however, with the type r sway bar however the mounts shocks and LCA's are difernt right? and people who are paying attention could figure it out.
yeah i have the bsq kit gonna do the r bar for the next time around. the car is in STS though i have i/h/e and spc lca's upper control arms as well as koni's on ground controls. i might have a high flow cat too which will throw me into STX, we'll see though i need a job first!!
Someone show that car how to rotate. Body leeeeeeann
rear sway bar and take the front strut bar off
Maybe you ment the front sway bar? which would result in more oversteer? (although it would probably end up in way to much oversteer)
Yeah, I don't understand the front strut bar either?
great job knocking down all those cones. post this in members corner, doesnt belong here.
Why do you have to be such a ***** all the time?
