Civic exhaust question
Old Feb 16, 2003 | 07:06 PM
RickChew's Avatar
Default Civic exhaust question
Ok, I was wondering what I would need to be able to bolt up a cat back exhaust from a 00 Civic SI to my 98 DX. I picked the exhaust up extremely cheap and I figured it flows at least a little better than my DX. Would I need headers from an EX? Or an EX cat? Or anything aftermarket? Just seeing if I can make this work cheap. Thanks guys! Rick
Old Feb 16, 2003 | 07:13 PM
poison's Avatar
Default Re: Civic exhaust question (RickChew)
You should not have problems bolting it up, but I would recommend getting an Si cat if the catback is for the Si.
You shouldn't have problems though.
Old Feb 16, 2003 | 07:42 PM
RickChew's Avatar
Default Re: Civic exhaust question (poison)
Thanks man! Does anyone else know any more about the cat? Thanks! Rick
Old Feb 16, 2003 | 08:21 PM
tominos's Avatar
you also need the ex header.
Old Feb 16, 2003 | 08:57 PM
KURRRRWA
Guest
Posts: n/a
You WILL have problems. The DX has the cat on the header, rather than down by the exhaust.
Like the guy before me said, you will need an EX header. You will also need an EX cat.
Old Feb 16, 2003 | 09:02 PM
RickChew's Avatar
Default Re: Civic exhaust question (KURRRRWA)
Ok, I figured i needed the EX header and Cat, so that was to be expected. Thanks for all your help guys! Rick
Old Feb 16, 2003 | 10:03 PM
deepnite's Avatar
if u want to keep ur existing header and cat intact..u could just put a new downpipe from the cat. down..then flange it at the end and hook up with the Si system
Old Feb 17, 2003 | 07:25 AM
RickChew's Avatar
Default Re: Civic exhaust question (deepnite)
On the EX, is the cat up infront of the engine like on a DX? Or is it down under? I was hopeing to get rid of the incredibly short exhaust manifold on the DX that I cant see as being power friendly. Thanks! Rick
Old Feb 17, 2003 | 11:05 AM
idreamsi's Avatar
io have a friend on here and i know her personally but forgot his screen name. He has a 96 dx sedan and he just installed a ex header and high flow with a 92-00 greddy evo. So it can be done.
Old Feb 17, 2003 | 12:03 PM
JforJonathan's Avatar
i dont think that it will fit because the si catback will only fit the 99-00 si and 92-00 ex
ozh_hawaiian
Feb 9, 2026 07:04 AM
oneman2halves
Honda Civic (2001 - 2005)
Jan 29, 2007 12:15 AM
Project_Civic
Apr 5, 2005 03:30 PM
tr4il
Dec 10, 2001 08:53 AM
