itr lca arms, advantages over stock gsr lca setup?
what are the advantages and disadvantages of the itr lca on a gsr? is it better to just switch the back 2 or do all 4 corners if upgrading to the itr lca? input and help is appreciated
ok so i just need to order the front bushings and the rear lca and bushings. i already have an itr sway bar on there and i am running kyb agx shocks. anything going to go wrong with this or should everything just simply bolt up and fit together?
you would need ITR rear shocks since other civic/integra rear shocks will not fit.
rear bushings are alreadyin the LCAs and the shocks.
miketegra
Jun 26, 2004 08:44 PM
P()()RB@Y
May 23, 2002 06:17 AM
