Lower Arm Question?
Lower Arm Question?
I have Tein Type SS damper on my 94 CX ... if I change the lower control arms to ITR control arms will I have any problems with the Tein's?? From what I know I need the ITR arms to hold JDM Spec dampers but I've seen stock shocks used with ITR arms?? How does this work?
Re: Lower Arm Question? (Beyond Imagination)
The rear ITR LCAs will not work with any US Spec rear shocks besides the Type R shocks and 88 CRX rear shocks. If you want to run Type R rear shocks you have to get Type R rear LCAs. The front ITR LCAs on the other hand are the exact same as GSR LCAs.
Re: Lower Arm Question? (RyanR)
What I want to do is use the ITR rear sway bar but in order to do that don't I need the ITR LCA?? Or will a GSR on work for the sway bar??
No, to use the ITR rear swaybar you can use any rear LCAs that have the threaded holes for the swaybar endlinks. But if your going to use the ITR rear bar on anything other than an ITR I would suggest you look into the Beaks reinforcment kit.
ok, then i got a question!
i have a 95 Civic CX Hatch, can i put ITR LCA on my stock rear hubs? And what shock/struts do i use in the rear? Will i then be able to use the ITR Rear Sway Bar? And where can i find that reinforcement kit?
Thanks.
vnt
[Modified by vntperformance, 8:00 AM 3/15/2002]
Thanks.
vnt
so can i use USDM ITR Sway Bars & ITR LCA's?
What struts do i use then? so my stock CX Hubs will be fine with this?
thanks.
vnt
[Modified by vntperformance, 8:26 AM 3/15/2002]
thanks.
vnt
Shark Tank
02-16-2003 05:06 PM
