ITR LCAs + 92' civic...any problems?
New User
I was going to get some ITR LCAs for my civic when I buy my suspension setup.Are there any problems installing the LCAs?The front ITR LCAs are the same as civics correct?
Also if I have the rear LCAs from the ITR should I buy the shocks and coilovers for the ITR?Itll bolt up correct?
Thanks
Thanks
Re: ITR LCAs + 92' civic...any problems? (P()()RB@Y)
I dont know about the front's being the EXACT same, but they are similar. The rear shocks for a 92 Civic won't "bolt" on. You'll have to a little modification to the fork of the shock.
But the shocks for a ITR will bolt up to the LCAs right?
Thanks
Thanks
The front ITR LCAs will also have stiffer bushings then other integras/civics so they are a good upgrade. Plus all of the Integra front LCA's have the bolt hole for the swaybar endlink, so you can easily run a stock swaybar up front if you get ITR/Integra front LCA's.
hazard_one
Suspension & Brakes
04-28-2005 05:44 PM
Shark Tank
02-16-2003 05:06 PM
