GM sychronmesh?
have anyone used GM sychronmesh fluid in there transmission...how did it feel..is it good?..is it safe?..let meeh know..im having like shifting problems..like not goin in smoothly and all. on my 90 hb tranny..
I use it.. and I would recommend it.
But don't get the one that is in the small bottle.. get the one that looks like a normal oil container which says "friction modified".. it's about 13.44 each.
you'll love it..
You can also mix half with honda MTF, I did that for a while.. but it's your choice..
you'll love it..
naw im down to spend that extra cash ..i jess dont want to be grinding..even thou i shift slow my gear ginds...then sometime when i downshift..sometimes it does not go in smooth..i gotta force it alittle..but sometimes it works jess fine.. that was after i use royal purple max-gear 75w90 fluid..i think that **** suck..or did i use the wrong weight..let meeh know..dont feel like buying a tranny yet..
I used it for awhile, then I shoot my center pin out of my dif through my tranny housing. Not saying this was anything but where and tear though. I am not blaming the synchromesh!!!!! After that though I will run honda fluid only.
you only need the "friction modified" if you have a clutch type lsd.
I've switched around with different fluids about 10 times, and this one works the best. The regular GM stuff is a waste of time IMO.
we put pennzoil syncromesh in my cousins 2000 accord but i couldnt tell you if there was any difference or if there is going to be any problems.
all i know is that the pennzoil syncromesh is GL-4 certified.
dam i jess change my tranny fluid and put in the GM synchromesh..and that **** hella good...no more grindin on second and i can downshift smoothly to 2nd gear on high RPMs... that **** is awsome...!!u all should use it....DAM
bk7794
Jun 22, 2011 05:11 PM
tallblondkid
Aug 18, 2004 03:59 PM
