Ring end gap questions
Old Feb 16, 2003 | 05:50 AM
Trey's Avatar
25 Year Member
Default Ring end gap questions
I gapped my rings on a freshly bored and honed block .25 OB and found all the gaps were larger than the new limits but smaller than the service limits per Helms.
Should I really worry about it buring oil?
Old Feb 16, 2003 | 09:10 AM
earl's Avatar
Default Re: Ring end gap questions (Trey)
Probably not.
Old Feb 17, 2003 | 04:02 AM
Trey's Avatar
25 Year Member
Default Re: Ring end gap questions (earl)
Thinking back, the gap specs didn't specify STD or OB in the Helms. DO I need to recalculate the end gap with an OB block? Like take the STD limits and add a certain amount to compensate for the larger bore or am I just thinking too hard as usual? :D
Old Feb 17, 2003 | 10:00 AM
sgT's Avatar
sgT
Are these factory rings?
I have foundthat factory rings rarely need to have the gap adjusted.
Old Feb 17, 2003 | 11:36 AM
Trey's Avatar
25 Year Member
Default Re: Ring end gap questions (sgT)
Yes, factory rings on factory pistons. Both .25mOB in a freshly bored block. 81.25mm bore.
I was thinking the same thing on the rings needing to be messed with since the bore was fresh and all.
Old Feb 17, 2003 | 04:49 PM
TREVER's Avatar
me too, as long as there within the service limit let it ride
you don't have much of a choice
Spoon84
Jul 19, 2010 09:22 PM
Spoon84
Jul 19, 2010 01:34 PM
mvp100
Feb 22, 2008 07:06 AM
nblanton
Oct 5, 2007 03:14 PM
Speedz
Nov 15, 2006 10:04 AM
