FS: CIVIC w/ B18B and RevHard Stage II TURBO KIT and MORE
Old Feb 16, 2003 | 01:42 AM
HuskerHybrid's Avatar
Default FS: CIVIC w/ B18B and RevHard Stage II TURBO KIT and MORE
you guys interested in a built turbo civic?
"8 grand under the hood"
these are not p^ssy mods here, these are essential power mods that will make you go fast, no bullcrap performance adders, just the meat of engine building. if you're looking to turbo your car and build up the bottom-end, it's done right here for you all in one. set-up is less than 4 months old!
__________________________________________________ _________________
<U>SPECS</U>
-'94 ls motor
-forged bottom end:
-Eagle/Endyne forged rods (tested to 600+ hp)
-JE forged pistons - 8.5:1 Compression
__________________________________________________ __________________
TURBO KIT SPECS:
-REVHARD stage 2 COMPLETE turbo kit
Stage: 2
Use: Street/Track
Part #: RHSTGII
MSRP: $3,499.00
Boost Level: 7psi
Injector Size: Stock
Horsepower/Torque: +100 / 260 ft/lbs
Rev Hard Cast Iron Manifold
Rev Hard T3/T04B Hybrid Turbo
Turbo efficient to 350hp
Rev Hard Intercooler 28x6.5x3 or
25x8x3.5 limited qty.
Deltagate (7-9psi)
Vortec Blow Off Valve
2.25" Aluminzed Mandrel Bent Piping
2.5" Downpipe
Progressive Type Fuel Regulator
High Volume Fuel Pump
Purosil Hoses & Clamps
Steel Braided -3 Oil Line
Oil Return Line
High Pressure Fuel Line
High Pressure Silicon Hose
Neccessary Vacuum Tee's
Neccessary Vacuum Lines
-450cc dsm injectors
-dual friction centerforce stage 3 clutch
-new timing belt and all new gaskets, hoses, and bearings
-head was left stock
vehicle has a v-afc for fuel support custom mounted in passenger side dash area.
dual pod a-pillar guages (1 boost guage, 2nd open)
35% tinted windows all the way around (except front, front windshield has 35% banner)
custom 2 1/4 inch exhaust 1/2 way back. aerospeed "bomb" muffler
$600 pioneer deck/mp3 player (this is one of the best decks pioneer makes) pioneer tweeters (loud as a mother ******) 2 10" memphis subs with crossfire amp.
the sound system is 1 of the cleanest sound systems i have ever heard.
body has a few cosmetic flaws, door dings, and the drivers side corner light has fallen out due to high speed traveling
~this car has not been "riced" out, no decals, no altezzas, no neon. this is purely a performance machine with plenty of room for you to do more to it. it has a rock-solid bottom-end and one of the best turbos you can buy for a honda already installed.
~BONUS~old engine will be sold with this car d16z6, with tranny ecu and new axles.
hey guys if you want a couple pics go to www.4bangercity.com
-&gt; PROFILES -&gt; 94 HONDA CIVIC EX
if interested you can e-mail me at "ninja9910@hotmail.com"
Located in Lincoln, NE
i'm willing to entertain questions, SERIOUS inquiries ONLY! No Low-ballers, flakers. I'm not here to waste your time, I certainly hope you're not here to waste mine.
$11,500 FIRM
[Modified by HuskerHybrid, 10:52 AM 2/16/2003]
Old Feb 16, 2003 | 02:14 AM
blufke's Avatar
Default Re: FS: CIVIC w/ B18B and RevHard Stage II TURBO KIT and MORE (HuskerHybrid)
good luck with the sale, but you should put it in the right forum.
Marco93EJ
Mar 24, 2006 03:42 PM
LearningNewb
Dec 12, 2004 03:19 PM
Elemental
Aug 5, 2004 10:45 PM
CoolKat
Jun 21, 2002 09:16 AM
