help! i have a stripped oil pan nut!
Old Feb 15, 2003 | 07:34 PM
turbohf's Avatar
Default help! i have a stripped oil pan nut!
k, this blows ***. im swapping oil pans and when i go to loosen all the nuts and bolts one just stripped. and of course its the one in the corner next to the tranny...
so whats the best way to get that little bastard off? thanks
Old Feb 16, 2003 | 06:50 AM
TREVER's Avatar
Default Re: help! i have a stripped oil pan nut! (turbohf)
pull pan, remove stud with pliers, use a bolt.
Old Feb 16, 2003 | 08:08 AM
turbohf's Avatar
Default Re: help! i have a stripped oil pan nut! (TREVER)
WTF are you talking about? i dont care about puttin the damn thing back on i cant get the ****** off...
Old Feb 16, 2003 | 10:33 AM
baonest1's Avatar
damn cuz calm down... he tried to help. try to grab the stud if any is showing and turn with pliers or somthing.. and hopefully the whole thing will turn.. or you can try to grab the nut or maybe put a smaller mm socket on there.
Old Feb 16, 2003 | 11:09 AM
turbohf's Avatar
Default Re: help! i have a stripped oil pan nut! (baonest)
the NUT i need of is the one that is holding the shield thing on, so i cant take the shield off and the oil pan is in the way on the other side...you understand??? im just going to cut the nut in half with my dremel
Old Feb 16, 2003 | 11:21 AM
tominos's Avatar
you mean you stripped the nut? get vice grips.
Old Feb 16, 2003 | 11:57 AM
turbohf's Avatar
Default Re: help! i have a stripped oil pan nut! (tominos)
Old Feb 16, 2003 | 01:09 PM
VTECR021's Avatar
Ok, im trying to make this clear, ok you stripped the nut itself? from using improper socket size or wrench size right.? If so, the only next way is to use a Vise Grip like others have stated. It works wonders for me. But if its rusted too, heating it up will help also. WD40 helps kill the rust too.
If nothing works, use dremel to cut the nut in half without cutting the stud itself too, to preserve the stud for next useage.
Old Feb 16, 2003 | 10:20 PM
turbohf's Avatar
Default Re: help! i have a stripped oil pan nut! (VTECR021)
yes the nut is stripped. i was using a 10mm, cuz thats what size they are. you cant get vise grips in that small *** area. no rust, **** is the oil pan its covered in nasty *** grimmy/oilly ****...
I GOT IT OFF!!! thanks!
djtsmith007
Jul 17, 2009 07:20 PM
HyphyBB6
Apr 13, 2009 05:18 PM
TahitianEG
Sep 5, 2006 09:41 AM
linx
Jun 16, 2003 09:15 PM
linx
Jun 16, 2003 01:29 PM
