Need Help, 95 EX 4 Door sounds very unhealthy!
A strange noise comes from under the hood, I would describe it as a high pitched ticking noise that is in sync with the rpm's. It starts immediately when the car is started and it changes pitch a little when you push the clutch in or out. I took the car to a dealer and they said it was the bearing in the clutch that my friend says is the throw out bearing. My friend however disagrees with the dealer because he thinks the noise should be very noticably different when you press in the clutch. What do you guys think? Thanks for the help.
ha, funny noise from sedan?? mines funnier, it only has 3 cylinders!! the other left out the side of the block. and yes, it still runs. sorry for jacking the post.
05foresterxt
25
Mar 29, 2011 07:47 AM
