Can I run GSR headers / cat. conveter in my Eg/GSR Hybrid?
I just noticed on IAS web site that the complete swaps come with the cat. converter. Just wondering if I can run the GSR headers and cat. converter in my Eg?
Do the headers / cat connect to each other or is this where a test pipe comes into play? Thanks for any help on this!
headers? how many are you using?
lol
jfwu
they send you the oem header and cat so you can get your swap installed asap.
just cut your exhaust shorter to mate up to the gsr cat's end
OR
you can get a testpipe made to replace the cat, made to fit the gsr header length, gsr header collector diameter, and the distance to reach the rest of the exhaust you have on your car.
lol
jfwu
OR
No seriously, you have to use the header at least since the D series wont fit a B motor, but you could use your stock cat if need be.
[Modified by VTECVillain, 11:55 PM 2/15/2003]
Sounds great! I'm going to just use the GSR cat. / headers and get custom 2 1/4" piping with a muffler. My brother runs his Accord with no cat. and it's wayyyyy to LOUD!
One more thing. Does the GSR header hang pretty low? My friend scrapped his DC Sports headers the other day where it meets with the piping and knocked it out of whack. A muffler shop fixed it but it's too low to the ground.
Thanks!
Thanks!
The GS-R header sits reasonably close to the oil pan in terms of height from the ground. Anything that would hit your header would probably hit that too.. so just be mindful of what's in the road and you'll be fine.
ek82
Oct 15, 2007 05:07 PM
