SAFC Setup - Having problems
1997 Integra GS (B18B), just got th SAFC installed but I am having some problems. First, the TPS sensor (at the unit) is reading 4.9XX V's and is not moving. Ideas on what it could be? Also the AFL is at 1% under acceleration and around 10-20% when I let off the gas, does this sound right? Thanks for any setup tips you might have. If there is a good site out there for this I would love to know!
Sounds like the TPS and the MAP sensor signals are backwards...i.e. the signal wires were hooked up to the incorrect wire. Also the S-AFC needs to be in pressure mode and the in and out setting needs to be at 6 for both. when your done you should not see an airflow percentage, it should be seeing manifold pressure and when the car is in just the on position and not running the pressure should be close to zero. Hope that helps.Check out A`PEXi's web site if you need the pin-out for the harness.
I just checked thier website and the pin out listed is 10X differnt then the one in the book. Back the the drawing board! - Thanks! There isn't a good website for a Newbie FAQ on this is there?
[Modified by Xscream, 11:30 PM 2/15/2003]
