sir-II vs. GSR
Old Feb 15, 2003 | 12:42 PM
solman
Guest
Posts: n/a
Default sir-II vs. GSR
sir-II vs GSR in a del sol. Im leaning towards gsr because im leaving it all motor. What do u guys think? Thanks
Ryan
Old Feb 15, 2003 | 12:44 PM
BackSideSA's Avatar
Default Re: sir-II vs. GSR (solman)
hmm...
there is this link up in the right hand corner that says SEARCH
and you wonder why people are ********
Old Feb 15, 2003 | 12:49 PM
solman
Guest
Posts: n/a
Default Re: sir-II vs. GSR (HybridHackBatch)
HEY! Thanks for the TIP. I dont "wonder" why people are ********. I know they are. Take urself for instance. Have a good day.
p.s. I know what the search button is dick. But I don't feel like reading about compression ratios and resleeving. FYI, i did the search and I just wanted some brief answers for MY specific situation.
Old Feb 15, 2003 | 12:56 PM
gamby's Avatar
This debate has raged on in about one hundered billion posts. These always spark the "B18C vs B16A" arguments. The B18C always wins these arguments.
If you can get a 170hp JDM SiRII B16A, it'll work spectacularly in your Sol, but more for roadrace/auto-x. It'll run low 15's in the 1/4.
The torque of the B18C cannot be had in the B16A no matter what you do. That torque also makes the car feel faster.
Basically, do what you want. Either one will make the car a performer. If you can get the B16A for a significantly cheaper price thean the B18C, I'd say go for it, and then use the difference to get a Koni yellows and Ground Controls.
[Modified by gamby, 4:05 PM 2/15/2003]
Old Feb 15, 2003 | 01:37 PM
hybrider's Avatar
Default Re: sir-II vs. GSR (gamby)
Old Feb 15, 2003 | 01:51 PM
pennies_hatchie's Avatar
Default Re: sir-II vs. GSR (hybrider93)
noobies!
nuff said
Old Feb 15, 2003 | 03:43 PM
solman
Guest
Posts: n/a
Default Re: sir-II vs. GSR (pennies_hatchie)
Thank you for those who gave informative replies. And who cares if im a "noobie" yea, i just got into hondas, but before this I had a Cougar that I modded for 2 and half years. Import scene is much different than domestic. Engine swaps are very rare, and when they are possible there is usually only one or two alternatives. Everyone needs to start somewhere, so stop padding ur ego by trying to make people new to the scene look stuiped.
Old Feb 15, 2003 | 03:51 PM
hey noobie...
try using the SEARCH BUTTON...
its the last button on the upper right corner of your screen
im pretty sure you'll get better responces by using it and itll probably be your closest friend
UNDER PRESSURE
Jul 30, 2004 05:27 PM
flippedoutasian
Jan 9, 2004 05:07 AM
rkn527
Feb 25, 2003 06:50 PM
theguy003
May 31, 2002 11:15 PM
JDMOption
Mar 7, 2002 10:29 PM
