Gauges HELP ME please
Ok I cant seem to get my dash off of my 93 Si, Im trying to get to my gauges. See, my speedomiter stopped working, and I was wondering if anyone had any clue as to how to take off the vent/dash in front of the gauges. I cant tell if its just clips, I dont want to break it. PLEASE I NEED HELP!
Search. There are a bunch of topics on this... if you had the time to reply to your own message, you certainly have time to use the search function.
Anyways...
Start by removing the two Phillips head screws holding the top of the bezel in place. Now grab the bottom of the bezel and pull it straight out. It has two spring clips that hold it in place. Remove the four screws that hold the cluster into the dash. Look at the back of the cluster for four wire harnesses. Remove the four wire harnesses from the back of the cluster. Remove the light bulb from the rear and undo the wire from all of its holders so that it hangs freely from the front of the cluster. The cluster will have tabs that hold the front and rear together. Push them all down and start to pull them out. Don't try to pull them out all the way until you have gotten all of them pushed in. Do this to all the black ones and the three clear ones on the bottom.
This was taken from Jdmfan.com Good luck and search next time.
Anyways...
the cluster comes out really easy. Pop the clock out, pop the hazard signal switch, take out the screws. Go to an automotive store like autozone and look it up in a book if you cant figure it out. BE CAREFUL WITH THE CLIPS!
hypnotic
Jun 13, 2003 10:44 PM
karmannghia
Nov 7, 2001 07:51 AM
