a/f gauge install help
Old Feb 15, 2003 | 05:25 AM
CRX SiR T's Avatar
Default a/f gauge install help
i installed an autometer a/f gauge into my car. it gets power, but it's stuck at the richest point, no matter what happens. i tapped into the line that connects to the o2 sensor, i believe it's a white/red wire. do i do that correctly? is it better to wire it to the ecu? where has everyone else wired their's?? thanks alot
Old Feb 15, 2003 | 05:33 AM
ThatRicerDaniel's Avatar
Default Re: a/f gauge install help (CRX SiR T)
no it wont get a correct reading at the ecu .. you need to wire it about 1 1/2 inches away from the actual o2.
Old Feb 16, 2003 | 07:07 AM
CRX SiR T's Avatar
Default Re: a/f gauge install help (NitrousDreamz)
i did that, and it's still acting goofy. it lights up about 10 different lights at once, and that part goes rich or lean. does anyone's autometer gauge actually work?
Old Feb 16, 2003 | 10:18 AM
Full-Race Henry's Avatar
mine worked. you have to connect it to the o2 sensor. my car needed to warm up the o2 before it was really working. while warming up, it was stuck on rich
Old Feb 16, 2003 | 10:26 AM
meancrx's Avatar
A/F gauges are scerwy anyway. I have used them for a few years and all of them do that no matter where you put the wire (closer to the O2 is best). Recently i have decided to use a 3 way A/f gauge (wideband). they cost a little more but are much more reliable and give correct readings and signals.
maddcrx
Honda S2000
Jun 26, 2008 03:55 PM
PearlWhiteAccord
Dec 31, 2005 01:40 PM
DohctorVtec
Oct 19, 2005 05:44 PM
X2BOARD
Jul 14, 2003 09:21 PM
civictypenos
Oct 10, 2002 07:40 AM
