i need some help
hey sup..well my problem is..when i start drivin my car around for about10-15 mins my car starts to bogg..an my idle starts to drop like its going to die..my ecu also threw a cel #9..any suggestions..thanx in advance
CEL #9 is the number one cylinder position (CYP) code.
To check it, dissconnect the ignition harness connector at the diestributer and probe terminals 4 and 8 with an ohm meter. it should be 350 to 700 ohms.
hope this helps any..
what motor do you have?? as far as i know, it a sensor that monitors where the no. 1 piston is. the plug is just under the Intake manifold on the drivers side. you can see the wires coming from behind the crank pullley. its not hard to get to.
