CEL TDC sensor position...Help?
Old Nov 13, 2003 | 05:34 PM
outbrakeridah's Avatar
Default CEL TDC sensor position...Help?
Hey just the other day when i started my car, it was silent...no crank or nothing...as i held the key in the start position for a while, my check engine light came out...forgot exactly what code it threw out ( i think it was 8), but it is the TDC sensor position...something like that...anybody experience this b4??? and how did you go about fixing it...now sometimes i have to hold my key in the start position for a while b4 it starts up...weird but i just need to know if anybody has had this problem b4...any help will do...thanks!
Old Mar 11, 2006 | 05:19 PM
97dc2's Avatar
Default Re: CEL TDC sensor position...Help? (outbrakeridah)
Im having thee same problem. Can someone pls help
Old Mar 11, 2006 | 07:27 PM
Diego Dangers.'s Avatar
in OBD1s, its in the distributor. change it, see if it goes away, heh.
EDIT: actually, nevermind, dont change it. see if there is continuity from it to the pinout on the ECU. maybe be a bad wire. or a bad connector.
hondasport2000
Aug 14, 2009 01:18 PM
PINKS
Aug 2, 2006 02:43 PM
PINKS
11
Aug 2, 2006 02:41 PM
gdout90accord
Mar 30, 2005 12:59 PM
CRX SiR T
Nov 1, 2003 08:26 AM
