CEL code 9 cyp sensor
Old Apr 24, 2009 | 03:55 PM
Hookeduphatch's Avatar
Icon6 CEL code 9 cyp sensor
cyp sensor code popped up, checked distributor everything checks out getting fuel.... engine will crank but will not start any suggestions?
Old Apr 24, 2009 | 05:07 PM
jdm_bones's Avatar
Default Re: CEL code 9 cyp sensor
What did you remove prior to having this problem, sounds like you might have some plugs crossed....Or something isn't connected, check all your senors/connectors.
Old Apr 24, 2009 | 05:37 PM
its fixed come to find out it was just a bad distributor so i took the dizzy from my 93 eg and swapped it over... car started but still sputtered like it was running 3 cylinders so checked spark on all the cables and low and behold number 4 cylinder wire was screwed so i replaced all the wires and now she runs like a dime.. thanx for the imput
Rhood
39
Apr 6, 2017 10:03 AM
accordcrx
Nov 24, 2005 02:03 PM
athoughts
12
Jul 3, 2005 10:16 AM
RaIn
Apr 20, 2003 08:05 PM
