I/C piping ?
Old Feb 14, 2003 | 02:18 PM
i3oricua's Avatar
Default I/C piping ?
I found a really great deal on some piping for my I/C but I'm stumped on which one to get. They have a 50mm pipe kit and a 60mm kit. I know the obvious is that the 60 will flow better because it is thicker or wider anyways. But it is worth the extra $75 for the 60mm? Also, I don't know how much that 10mm difference will interfere with trying to retain my a/c. Anyone got some answers?
Old Feb 14, 2003 | 02:21 PM
Smashback's Avatar
Default Re: I/C piping ? (i3oricua)
Your IC piping should'nt really come anywhere close to your A/C. Typically people use 2.25" but I can't think of what 50 and 60mm equals in inches.
Old Feb 14, 2003 | 03:35 PM
i3oricua's Avatar
Default Re: I/C piping ? (Hatchblack)
bump..........fo shizzle my nizzles - anyone else know?
Old Feb 14, 2003 | 03:42 PM
VTECPWR's Avatar
50mm is ~2.25" and 60mm is ~2.75". Is this ID or OD? Makes a difference and not every place measures the same way. How much do they want for the IC piping and where are you getting it?
Old Feb 14, 2003 | 03:51 PM
i3oricua's Avatar
Default Re: I/C piping ? (VTECPWR)
http://www.performancecenter.com/veh...+UNIVERSAL+FIT
Old Feb 14, 2003 | 07:17 PM
Broken Gearbox's Avatar
would it be cheaper just to buy some pipes from Jcwhitney and DIY or does that consist of alot of work?
Old Feb 15, 2003 | 11:17 PM
i3oricua's Avatar
Default Re: I/C piping ? (x lP lL i c i t)
Whats the difference between od and id? And which will give the best results? I'm not looking at huge horse here, just between 230-290 i guess, or whatever. Mostly stock form on my engine. Anyone?
Old Feb 16, 2003 | 01:25 AM
jthelman's Avatar
50mm is slightly under 2" (1.96), and 60mm is slightly over 2.25" (2.36)
Dat1BVtecN
Jan 16, 2008 07:50 AM
tony n.
Apr 25, 2005 08:28 PM
Wo-Nelly
Dec 10, 2002 01:11 PM
bboychris
Oct 2, 2002 02:46 PM
