ecu troubles on swap, rev limiter at 6500rpms... someone help!!!
Old Feb 13, 2003 | 10:50 PM
pearlwhitecrx's Avatar
Default ecu troubles on swap, rev limiter at 6500rpms... someone help!!!
i got a problem guys, i took out my chipped p72 ecu in my gsr swap and plugged a stock one in... after that i got a check engine light and can no longer rev past 6500rpms (used to 8200) so i swapped the original one that WAS working fine and the same problem happened... WHAT COULD IT BE, i also have a vafc hooked up and when vtec turns on the vafc doesnt register that its "on" but i know its on cuz i can hear it.... any ideas people? maybe i disconnected a wire when unplugging the ecu? its a 93 cx hb with a 94 gsr obd1 swap
Old Feb 14, 2003 | 07:39 AM
Phaze2 Mike's Avatar
Default Re: ecu troubles on swap, rev limiter at 6500rpms... someone help!!! (pearlwhitecrx)
defintly sounds like a wire. Check the pins, the male/female VAFC connectors, and the like.
slowgsrswap
Jul 8, 2007 10:27 AM
Nisif
Jan 10, 2005 07:06 PM
madhatter07
Nov 17, 2004 07:53 AM
Hybrid 350GT
Nov 11, 2002 10:24 AM
DOHCVTECDELSOL
Apr 30, 2002 05:45 AM
