Will a B18c5 (type-r) LSD fit in a 96 LS tranny?
Old Feb 13, 2003 | 06:11 PM
turboex's Avatar
Default Will a B18c5 (type-r) LSD fit in a 96 LS tranny?
If so what all is needed?
Old Feb 13, 2003 | 06:30 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Will a B18c5 (type-r) LSD fit in a 96 LS tranny? (turboex)
it should go right in, no problem
Old Feb 13, 2003 | 06:34 PM
turboex's Avatar
Default Re: Will a B18c5 (Boosted97Lude)
I am being told by thers that it wont.
See on quaifes site the part number for the LS and b16a are the same. But the gsr and the type-r are the same too. So im guessing that they are diffrent. Wheres Earl? you know this stuff
Old Feb 13, 2003 | 07:33 PM
SuperTeg95's Avatar
Default Re: Will a B18c5 (turboex)
It will not work with the LS (main?)shaft becuase it is geared for a 4.26 final drive and the Type R is a 4.40 final drive. This means the type R has a bigger final drive so the teeth won't match up. However if you swapped all that out the diff would physically fit into the tranny.
Old Feb 13, 2003 | 07:37 PM
integra_gsr98's Avatar
Default Re: Will a B18c5 (SuperTeg95)
From what I've seen is just the ring gear is necessary, however I do not know about the main shaft.
[Modified by integra_gsr98, 12:39 AM 2/14/2003]
Old Feb 14, 2003 | 04:21 AM
turboex's Avatar
Yep this is what i said. Do to the diffrent ratio the pinnion and ring will not match. I also contacted a few otehr companys and they said its a no way job and ill not go. Thanks guys. Kinda made sense to me to start with but had to check.
was kinda obvious when quaife uses the same part for the LS and the b16a. and a diffrent part for type-r and gsr. but i just had to check. thanks guys
[Modified by turboex, 1:22 PM 2/14/2003]
Old Feb 14, 2003 | 06:05 AM
tony1's Avatar
[QUOTE I also contacted a few otehr companys and they said its a no way job and ill not go. [Modified by turboex, 1:22 PM 2/14/2003][/QUOTE]
It can be done, but you have to change the ring and pinion gear to a type r or gsr...
Old Feb 14, 2003 | 06:20 AM
Default Re: Will a B18c5 (tony1)
So all that is necessary for Type-R LSD install is the diff and a type-r or gsr ring/pinion gear?
Which is just part 8 on this page, correct? (I am not a tranny person so please forgive me...)
http://www.acuraautomotiveparts.org/...CLUTCH+HOUSING
[Modified by integra_gsr98, 9:24 AM 2/14/2003]
Old Feb 14, 2003 | 06:22 AM
turboex's Avatar
Default Re: Will a B18c5 (integra_gsr98)
Yep ring and pinion have to match
eride89
Apr 14, 2011 03:34 AM
Chav3
Jul 16, 2007 01:16 PM
dash
Aug 14, 2006 02:06 PM
Slimm-rw-
Apr 5, 2004 12:01 AM
