... eagle rods... h-beam vs i-beam...
Old Feb 13, 2003 | 03:45 PM
1.8T_EG's Avatar
Default ... eagle rods... h-beam vs i-beam...
... just curious... what's the difference between the two (h-beam vs i-beam)...
Old Feb 13, 2003 | 04:18 PM
Smashback's Avatar
Default Re: ... eagle rods... h-beam vs i-beam... (1.8T_EG)
It really depends. If you are just sitting there looking forward, they are H beams. Once you swivel your head 90 degrees either direction, then they become I beams.
Old Feb 13, 2003 | 05:16 PM
inspyral's Avatar
Default Re: ... eagle rods... h-beam vs i-beam... (Hatchblack)
The Crower and Honda rods are I-beam, the Eagle is H.
Old Feb 13, 2003 | 07:07 PM
avividmemory's Avatar
Default Re: ... eagle rods... h-beam vs i-beam... (inspyral)
don't quote me on this, but I always thought it was because the top of crowers/hondas flared the top ring out to create a I-shape...and the eagles dont flare leaving the shaft of the rod straight and thus looking like an H...
Old Feb 13, 2003 | 07:37 PM
1.8T_EG's Avatar
...good one... ...anyways, are there any advantages to running one or the other?? ...i searched on here and i thought that one was better for high rpm's... correct me if i'm wrong... thanks...
Old Feb 13, 2003 | 08:42 PM
filetofit
Guest
Posts: n/a
I think an H-beam design will have a slightly lower mass moment of inertia since the mass is concentrated nearer the centerline of the rod. THis would make it better for high RPM. However for rod buckling which I imagine is the failure mode for high-high cylinder pressures (like in FI) the material should be concentrated away from the buckling axis. Most likely bucking/bending would occur about an axis parallel to the crank since in the other direction the end conditions are "fixed" ( ie not allowed to rotate).
Old Feb 13, 2003 | 09:55 PM
mos's Avatar
mos
Default Re: ... eagle rods... h-beam vs i-beam... (filetofit)
So basically H beam is good for your 10k rpm n/a motor, I beam is good for your 30psi terbod motor... unless I've got it wrong?
raverx3m
Dec 21, 2015 08:28 AM
prelude beast
Jul 25, 2003 08:26 PM
Cyber ITR
Oct 6, 2002 05:25 AM
done
Aug 28, 2002 06:39 PM
done
Aug 28, 2002 06:19 PM
