Need help with clutch...ASAP!!!
Honda-Tech Double Platinum Member
today i tried to install my Exedy Clutch(full face organic) in the LS engine that im about to put into my CRX. Well it doesnt fit right at all. The Pressure Plate wont sit flush witht the Flywheel. It will fit right when the Disk isnt in place...but when the it is the PP wont fit right. There is abou a 1/4 inch between the PP and the FW. Why is it doing this? I know that the disk is in the right way...thats not the problem. What else could it be? The FW was just resurfaced and when they were doing it theybroke off one of the studs that is used for alignment...i dont think that tat is the problem either b/c like i said, it fits when the disk isnt in there. TIA for the help.
PS-That throw out bearing is a BIYATCH!!!
Sean
Sean
Did you use an alignment tool when installing the clutch to make sure it lines up correctly. It will tell you how to do this in the service manual. If that doesn't work you might have the wrong year clutch disc for your engine.
Its a 92 Ls and i ordered one for the 92 LS. I think that the model number was 08-800a from http://www.clutchcityonline.com . I did use the alignment tool and it worked right...i just dont know what is wrong. I wanted to put my engine in Saturday or sunday so i need to get this figured out FAST. Thanks.
PS-Clutch city onlie is a great place to work with. They had awesome customer service and they got the cutch to me in like 3 or 4 days.
to clutch city online
Sean
[Modified by sCeRaXn, 2:27 AM 2/14/2003]
to clutch city onlineSean
By the way...when i got the engine it had a clutch on it from a different tranny...i think that it was a b16 one but im not sure. I dont know if that heps or not...just thought id let you know.
Sean
Sean
I figured that it would stick out a little but i didnt think that it would stick out that much. It sticks out like a 1/4 to 1/2 inch. Is that normal?
Sean
Sean
all clutches do that ...once you torque down the pressure plate bolts then it will sit flush
also pull out the broken stud and put in a new on
[Modified by 89civicdx, 4:44 AM 2/14/2003]
[QUOTE]also pull out the broken stud and put in a new onQUOTE]
I cant do that because the engine is going in tomorrow. I wish that i had time to do it but i dont. Do you guys think that it will hurt anything? I was told that the only thing they are there for is to line up the PP. Should i out off the swap just for this little dowel?
Sean
Sean
Sean
Sean
you say it had a b16 disk in it then you have a 90/91 tranny not 92, you need to get the 90/91 disk for it, hopefuly they will let you exchange the disks
90/91 teg disk ->cable b16 tranny
Xemu
Jun 29, 2007 10:43 PM
hmtcrxsir
Oct 6, 2005 11:01 AM
PHO-SHIZZLE
Feb 17, 2005 12:51 AM
opto_isolator
Sep 22, 2004 08:03 AM
