need help quick guys----crank pulley bolt q's
Old Feb 13, 2003 | 03:15 PM
hatchdrvr's Avatar
Default need help quick guys----crank pulley bolt q's
Is the crank pulley bolt on the B16 reverse threaded? ie clockwise loosens and counter-clockwise tightens? Also I've heard that using an impact gun on the bolt is bad for the motor. is this true? If so what is the best way to remove it? Any help is appreciated.
Old Feb 13, 2003 | 04:00 PM
owen_the_soyboy's Avatar
Default Re: need help quick guys----crank pulley bolt q's (hatchdrvr)
it is standard threaded.
lefty loosey as they say.
just removed mine this past weekend.
man that sheeeeeet was on there TIGHT!
I used a hex tool I bough tonline to hold the crank pulley in place, that tool goes on the end of a 1/2" breaker bar, but I suppose you could buy/borrow/rent a chain type of pulley holder.
I slipped a 4 foot long piece of exhaust piping over this breaker bar, giving me 5 feet total of leverage just holding the pulley...
I lodged this jumbo lever arm setup against the ground.
Then with a 19mm deep socket on another breaker bar, I also added a 4 foot pipe to this bar, and gave a few slow pulls...
ta daaaaaaaaaa it came loose in 1/4 turn!
made noises so loud that my roommates thought a beam broke in the basement!
(engine is on a stand downstairs)
and there was a puff of smoke/dust too, man that bolt hasnt moved since my block was asembled in Japan all the way back in late 1993, I think I'm gettin' a bit teary eyed.... sniff sniff...
GOOD LUCK BRO!
its all about leverage! get yourself a 4 foot pipe on the ratchet !
[Modified by owen_the_soyboy, 8:01 PM 2/13/2003]
wmac547
Mar 8, 2014 03:28 AM
grngsr01
Oct 23, 2005 05:47 AM
luti
28
Jan 9, 2005 01:05 PM
mike1114
Jan 31, 2004 03:19 AM
arren123
Mar 11, 2002 06:08 PM
