faulty wires around my ecu are causing my car to die
Old Feb 13, 2003 | 08:01 AM
Aeka GSR's Avatar
New User
Default faulty wires around my ecu are causing my car to die
Wires are fucked up on the ecu wire harness. If my ECU isnt sitting in the correct angle the car will die. There was a time when I would disconnect the ecu when I was going to school, that screwed things up. I tried to see if I broke any solder joints on the ecu and everything is clean and I can't localize what wire is causing the problem either so I'm thinking of just replacing the whole wire set and not deal with these problems again.
Where can I get a replacement or is there a way to localize the wire? There are so many of them.
nmhuntr
Sep 30, 2009 05:56 AM
hawj_boi_1
May 30, 2006 05:54 PM
BigDaddyRich
10
Aug 21, 2002 09:47 AM
