Transmission fluid??
Old Feb 13, 2003 | 07:20 AM
All Motor TypeR 133's Avatar
Default Transmission fluid??
Somone on this site said that you can use the GM synchromesh transmission fluid friction modified an it help's out your tranny an will not hurt it an I was just wondering if that is ture or not, because it's time for mine to be changed??
Old Feb 13, 2003 | 07:22 AM
Chris N's Avatar
Default Re: Transmission fluid?? (All Motor TypeR 133)
What is wrong with Honda MTF? Works great for me. When I changed my fluid last, the tranmission felt much less notchy.
Old Feb 13, 2003 | 07:23 AM
Dave-ROR's Avatar
The GM stuff is good. Honda MTF is good too but the GM stuff works better according to some people. I use Redline which some people on here will tell you that it'll ruin your tranny in 5 miles. ~50k here with no problems
Old Feb 13, 2003 | 07:57 AM
Fuuma0083's Avatar
Default Re: Transmission fluid?? (FyrStarter)
i use redline as well. And the problem people talk about it is only because of human error.
Old Feb 13, 2003 | 11:18 AM
onyx00's Avatar
Default Re: Transmission fluid?? (Fuuma0083)
No, it's cause you should not use Redline. Use Honda MTF. If you are having problems with Honda MTF then there is something wrong with your tranny. If you want to mask the problem fine, have fun, use something like GM that will hide it. but the end result will not be good.
Old Feb 13, 2003 | 12:02 PM
Dave-ROR's Avatar
Default Re: Transmission fluid?? (onyx00)
Uhmm my tranny had no problems when I switched to Redline, nor does it now. I guess you should only use honda motor oil too right? Honda fluids aren't ALWAYS the best. Their MTF is very good, but that doesn't mean that people using something else are "hiding" a problem.
Old Feb 13, 2003 | 12:48 PM
TypeR 01 886's Avatar
How tough is it to change transmission fluid? And how much would it cost as the dealer?
Old Feb 13, 2003 | 01:00 PM
Chris93Si's Avatar
Default Re: Transmission fluid?? (TypeR 01 886)
Very easy, not much harder than changing your oil you can definitely do it yourself. Not sure how much the dealership would charge but I bet if you had them do it they'd use motor oil and not MTF. to Honda dealerships.
yamahapunk154
13
May 12, 2009 07:49 AM
dohcgarage@714
Honda S2000
11
Sep 12, 2008 01:39 PM
avargas28
Aug 13, 2008 12:33 PM
wastedyouth2542
Jul 16, 2008 05:22 AM
SickIntegraWon
Mar 28, 2007 10:50 PM
