hey guys quick question..On a non hid jdm front end can you ...
Old Feb 13, 2003 | 07:17 AM
northwestR's Avatar
Default hey guys quick question..On a non hid jdm front end can you ...
can you still add hid's to it? or can you only get the aftermarket ones? Philips ext..anyone know if they are still 9006 bulbs?
Old Feb 13, 2003 | 07:18 AM
hungsteR's Avatar
Default Re: hey guys quick question..On a non hid jdm front end can you ... (northwestR)
Please do a search. This topic must be covered at least 3 or 4 times a week. Actually, if you scroll down this page or on the next there should be a several page thread on this subject.
Old Feb 13, 2003 | 07:28 AM
northwestR's Avatar
Default Re: hey guys quick question..On a non hid jdm front end can you ... (hungsteR)
i couldnt find it...if you dont want to help me out then dont post thanks...
Old Feb 13, 2003 | 07:31 AM
Reid's Avatar
Global Moderator
You clearly are inept or lying.
The answer to your question is yes.
Old Feb 13, 2003 | 08:50 AM
Padawan's Avatar
Darth ModerVader
Default Re: hey guys quick question..On a non hid jdm front end can you ... (Reid)
Reid - I'm not sure what you mean by "yes". Without modifying the entire headlight housing, how could you add anything but an aftermarket retrofit kit to the non-HID JDM headlights? Or was your "yes" just to the 9006 portion of the question?
Old Feb 13, 2003 | 08:51 AM
Reid's Avatar
Global Moderator
Default Re: hey guys quick question..On a non hid jdm front end can you ... (Padawan)
Once can install an HID kit with the non-HID projectors, or do it the right way and install the OEM HID headlights.
Old Feb 13, 2003 | 09:05 AM
Padawan's Avatar
Darth ModerVader
I just took this to mean, "Can you add OEM ITR HID's to the non-HID headlights, or can you only add aftermarket retrofit kits (e.g. Philips, Catz, etc.)?"
Old Feb 13, 2003 | 09:49 AM
just4show's Avatar
YES you can at aftermarket HID's to the non-HID headlight housing. However, I dont think you can add JDM HID's to a non HID housing. I have the JDM HEADLIGHTS with aftermarked HIDs and it works just fine! You may have a problem with sealing the back of the housing because the JDM HID ballast is what seals out the water....a little duct tape/electrical tape and your good to go.
Old Feb 13, 2003 | 10:53 PM
Flamenco-T's Avatar
Default Re: hey guys quick question..On a non hid jdm front end can you ... (just4show)
you can also buy the cover for it at your local acura dealership that has access to JDM parts
Old Feb 17, 2003 | 11:33 AM
junk yard sol's Avatar
i have the jdm hids and i took them apart out of curiosity. they are totaly diff. you can only add aftermarket not oem jdm and the non hids are a 9006
VTEC_PRODUCTION
Jul 18, 2007 05:45 PM
IBriaIN
Mar 7, 2005 01:07 AM
deeksmooth
10
Jan 11, 2005 07:22 PM
mofo 80
36
Nov 4, 2003 11:45 AM
ic0n
May 28, 2003 08:16 PM
