hid question
Re: hid question (**** 80)
ok you guys are confusing two different things. the diffuser is the piece of metal that covers the end of the bulb. the shield for hids is an adapter that makes it so that there isn't any upward reflection of light.
edit:
that metal adapter is the shield.
edit:
Re: hid question (enrique)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enrique »</TD></TR><TR><TD CLASS="quote">the shield for hids is an adapter that makes it so that there isn't any upward reflection of light.</TD></TR></TABLE>
This is what keeps from blinding everyone on the road which he is talking about.
Re: hid question (t0p_sh0tta)
Anyone actually have these on there 5th gen civic?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">Pick them up here for the not so low price of $22.50 a piece!!! </TD></TR></TABLE>
h4 is a bulb used in stock civics, if you look at that shield you notice 3 notches on it (all may not be visable) that allows you to use a d2s or d2r bulb in stock housings. the d2s and d2r has a smaller base and are stock for hid equipped cars. the shields are used to create a nice cutoff line so it doenst blind everyone down the road while illuminated the road directly in front of you (and not the trees and sky)
d2s bulbs are usually used with projectors while d2r bulbs have a metal shield placed on the bulb itself; usually used in reflective housings.
Re: (phantom_sol)
i just got a set of maxima hids. i'll probably install it within a month. i hate my work schedule. it's hard to get a weekend off. i'll take some pics.
Re: (**** 80)
so the ones in this link
http://www.casperselectronics....e.cgi
can make a d2s or a d2r bulb fit into a h4 and no further modding is needed? also how does it stay on? epoxy? just wanted to make sure before i buy it.
thanks
thanks
Re: (**** 80)
thats the place. your bulbs are kept in place with a wire stay inside the headlight housing. the adapter sits in between the housing and the bulb. so the wire keeps the bulb in and the bulb is held in place with the adapter. once you get the bulb out you will see. I would recomend taking the headlight off the car as it will be easier to work with and you will be less likely to **** something up.
