air being pushed out of oil filler opening during idle. Normal or compression leak?
Old Feb 12, 2003 | 10:37 PM
93TurboSi's Avatar
Default air being pushed out of oil filler opening during idle. Normal or compression leak?
when i remove the oil cap while the car is idling air is rushing out of it. is it normal for the air to be coming out of the oil filler opening while the car is idling or does that mean i have a compression leak.
Old Feb 12, 2003 | 10:46 PM
poo flinger
Guest
Posts: n/a
Default Re: air being pushed out of oil filler opening during idle. Normal or compression leak? (93TurboSi)
Blow by. Valve seals are bad.
[Modified by I can't believe this ****, 1:46 AM 2/13/2003]
Old Feb 12, 2003 | 11:06 PM
blu_si's Avatar
Default Re: air being pushed out of oil filler opening during idle. Normal or compression leak? (I can't be
So where can you get new seals? I think i need to rebuild my whole vavletrain. I got some gsr cams waitin, but where can i get seals?
Old Feb 13, 2003 | 02:06 AM
nd8ch's Avatar
i think its normal, but dont quote me. if valve seals caused it, i think you would just lose compression. and waste gas. Blow by is somewhat normal according to my mechanic, if its excessive...then you're piston rings are needing a replacement.
if there was absolutely no blow by, then there wouldnt be a need for breathers and return lines.
Old Feb 13, 2003 | 02:19 AM
Soulless's Avatar
i dont remember mine doin that so, id have to say its bad.
1990accordpnw
Mar 6, 2015 02:23 PM
red91hatch
May 18, 2008 11:32 AM
Dohcvtec59
Aug 11, 2004 08:13 AM
crx1856
Nov 16, 2003 12:03 PM
Witty
Aug 15, 2003 09:05 AM
