90 integra trailing arm/rear disc brake question i need this one guys i have faith
ok heres the deal i have 2 sets of trailing arms from 90 tegs one has abs.the other one is non abs but is complete calipers and all but the lower control arm bolt has been welded in on one side i wanna swap the non abs brake set up on the abs trailing arm.r they the same?
Yes they are the same, the only difference is the ABS one has a sensor, if you want you can remove the 19mm spindle nut on the rear and the four torx bolts, and swap the entire spindle over to the ABS arms. If you need anymore assistance let me know and I'll send you the Helm's Manual for the brake system to aid you.
So, there is no problem putting rear disc brakes from a 90 Integra onto a 91 DX hatch?
-larry
mik101
Apr 18, 2006 04:12 PM
