deciding on what 2-5/8 gauges i should buy.
Old Feb 12, 2003 | 05:07 PM
allmotor.net's Avatar
Default deciding on what 2-5/8 gauges i should buy.
im going turbo and buying all my parts now. i want to have like about 6 gauges to montior whats going on. i want to get all the same gauges because im just so picky. and i dont want to spend hundreds of dollars on just gauges. what is a good brand to buy that look good. i want to preferably have a white backround of black with amber lit. post some pics with prices
Old Feb 12, 2003 | 06:12 PM
TeAm IllUsIonZ978's Avatar
Default Re: deciding on what 2-5/8 gauges i should buy. (allmotor.net)
Well good gauges with a good cost would be Autometer, The if your going run turbo will of course need boost guage, air anf fuel ratio, fuel pressure, oil pressure, oil temp, water temp, and should have a exhaust temp guage... Then white backround ones are called Phantom, they all light up except air and fuel ratio and you will have to change the bulb to light up amber.. P.S the exhuast will probaly cost you the most ...hope that helps
Old Feb 12, 2003 | 06:14 PM
Default Re: deciding on what 2-5/8 gauges i should buy. (TeAm IllUsIonZ978)
o yea you can check them out at WWW.AUTOMETER.COM
Old Mar 16, 2003 | 12:16 AM
kHoA DoGG's Avatar
which ones are the most essential?
96integraLS
Dec 9, 2004 12:51 PM
JSR3STS
Feb 9, 2003 05:21 PM
RCautoworks
37
Dec 23, 2002 05:03 AM
E46M3CB
May 30, 2002 08:27 AM
Snafu-Si
May 3, 2002 09:27 AM
