glove box afc
can someone tell me how they mounted there afc and maybe gauges in the glove box. i dont want to buy the kit. also does ne one have the dimesions or a template to make a piece that holds them in. thanks
only found this and i only have the afc and 1 gauge
You must if you want to mount your afc in it. Get a tape measure.
I used an old piece from a carbon fibre hood to mount my cd-changer in the glove box. You can use whatever material you like. Just dont get something too thin.
You can fiberglass it, make a mold so the bottom is flat and lay fiberglass on top of that, and then when you pull it off of the mold the bottom will be perfectly smooth (if the mold is smooth and you can then use that).
Mike
[Modified by dwn-shift, 6:13 AM 2/17/2003]
Mike
dwn-shifts method looked great......he made a custom pod for his gauges and afc out of the plastic trim with the vents that goes around the gauges in his hatch. I saw it at the meet today and was definatley impressed.
Sanded balsa wood with felt over top and subtle holes drilled into the back of it would look just cherry
Not a lot of work and it can look really good if you do it right.
crxforum
Audio / Security / Video
Mar 23, 2003 07:18 AM
