greddy oil filter "sandwitch" adapter for sending oil to turbo
has anybody ever used of of these to plumb lines to the turbo??? just a thought i think my "T" configuration is leaking. Any tips i have already done a search.
call greddy.. i did and i asked the same question about the sandwich adapter and they said no...i forgot the reasons...but ask and they shall answer.... go with the Golden Eagle mfg. adapter
we suggest using these. not only does it lower the inlet oil pressure, it also allows only filtered oil to the turbo (from what weve seen of the GE unit). when you "T" off of the factory pressure sensor, you are coming directly off of the pump, no filtration and high pressure. as far as pressure is concerned, the turbocharger only needs 30psi to operate.
correct me if im wrong, but coming off the pump at WOT and high rpms, im guessing it to be close to ~90psi.
again, just our suggestion.
edit: what happened to our avatar??
[Modified by CHEAPTURBOdotCOM, 1:03 AM 2/13/2003]
ThePro
Jun 29, 2005 07:43 AM
khmboostedeh2
Sep 19, 2004 02:47 PM
