Connecting Door Trigger Input on DEI Alarm on 92 Civic (already searched)
Old Feb 11, 2003 | 11:37 PM
smnowell's Avatar
Default Connecting Door Trigger Input on DEI Alarm on 92 Civic (already searched)
Ok, me and my friend are trying to install my DEI Clifford alarm on my 92 Civic. We are trying to figure out which wire will function the (-)Door Trigger Input. DEI printout says Green/Red, but we tried that and it didn't work. Anyone know which wire, or maybe that was the right one and we just didn't have a good enough connection?
Old Feb 11, 2003 | 11:59 PM
s13_240sx_92's Avatar
Default Re: Connecting Door Trigger Input on DEI Alarm on 92 Civic (b16a ferio)
I'm having the same prob. I was told that is was a light green wire with a red stripe. I can't seem to find one(driver's side kick). Only two green/red on the same harness. Let me know if you find this one out. I'll let you know too.
Old Feb 12, 2003 | 06:48 AM
nOOber's Avatar
its there.
what are you testing it with?
do your all your doorpins work on the car? does the dome light turn on when you open any door?
[Modified by nOOber, 10:48 AM 2/12/2003]
Old Feb 12, 2003 | 07:01 AM
99_BlackSI's Avatar
I checked my DEI Techsoft Program and it said that for a 92 Civic the Door Trigger wire is lt.green with a red tracer. It also said it can be found in the driver side kick panel. Try stripping the wire again and retesting it with a good multimeter.
Dave
Old Feb 12, 2003 | 02:50 PM
Humm just froze my *** off again and still no good trigger wire. I guess I'm just gonna run wires from each pin and put some diodes to isolate them. I really didn't want to go this route, but i think i must be friggen color blind or something
Old Feb 13, 2003 | 04:29 AM
nOOber's Avatar
Default Re: Connecting Door Trigger Input on DEI Alarm on 92 Civic (s13_240sx_92)
follow the drivers door pin to the front of the car for about 2 or 3 feet.
Old Feb 13, 2003 | 07:20 PM
Desslok's Avatar
Default Re: Connecting Door Trigger Input on DEI Alarm on 92 Civic (nOOber)
Heres a tip for that wire, if you have trouble finding it in the kick panel, pull off the driver side pillar and find it in there, it runs up there to get to the dome light.
Old Feb 13, 2003 | 07:35 PM
I just ended up wiring each door pin and using diodes works fine. Thanks anyway
konidude
Audio / Security / Video
Oct 17, 2006 09:11 AM
Dub C
Mar 17, 2006 10:33 AM
BDogggUT34
11
Aug 17, 2005 01:02 PM
suspendedHatch
13
Apr 28, 2004 07:50 PM
intezn
Sep 3, 2003 06:39 PM
