how many lbs to recover NA hp??
Old Feb 11, 2003 | 08:54 PM
ZERO COOL's Avatar
New User
Default how many lbs to recover NA hp??
When I replace my stock pistons with turbo application ones, I know I'll lose some horsepower due to the lower compression. My question is, how many pounds will I have to boost at on a b16a just to be back at my normal HP level? (160hp) I will also be putting on a thicker head gasket as well.
Old Feb 11, 2003 | 08:57 PM
twkdCD595's Avatar
Default Re: how many lbs to recover NA hp?? (ZERO COOL)
very little... would guess a couple pounds of boost... not sure what everyone else thinks?
Old Feb 11, 2003 | 09:01 PM
VaporTrail's Avatar
New User
loaded question, all depends on turbo size, but you'll never have less power with a properly designed and operating turbo system than the n/a setup it replaced.
Old Feb 11, 2003 | 09:52 PM
mos's Avatar
mos
Default Re: how many lbs to recover NA hp?? (VaporTrail)
If I had to pick a number I'd say around 1psi, going from say 10:1 to 9:1, but I don't have to pick a number.
Old Feb 11, 2003 | 11:30 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: how many lbs to recover NA hp?? (mos)
maybe 2 psi and you will make more then n/a. if the turbo is efficient down there.
Freemananana
Oct 15, 2013 09:40 AM
eg9_fann
Mar 16, 2010 04:04 PM
Tjabo
Mar 10, 2009 10:39 AM
maniacmidge
25
Jul 23, 2007 07:07 PM
JustinL
May 25, 2005 06:17 PM
6, hp, na
