Can you identify these struts?
Old Feb 11, 2003 | 04:01 PM
T_Rex's Avatar
Default Can you identify these struts?
A friend told me he thinks they're stock, but I don't think they are. If you know what they are, let me know! Thanks in advance!!
Old Feb 11, 2003 | 04:03 PM
driftt's Avatar
Default Re: Can you identify these struts? (T~Rex)
they look pretty stock to me, that looks like a honda part number there on the little sticker
Old Feb 11, 2003 | 04:09 PM
JaiDM's Avatar
Default Re: Can you identify these struts? (driftt)
they look liek stock to me.
nice springs
[Modified by JaiDM, 1:10 AM 2/12/2003]
Old Feb 11, 2003 | 04:17 PM
T_Rex's Avatar
Default Re: Can you identify these struts? (JaiDM)
nice springs
Thanks, they're H&R Sports. I didn't have enough $$ to get good struts when we did the springs last year, so I just used what was on there. Surprisingly, the ride isn't that bad.
The chassis has close to 200K, so there's no way the struts are original, is there? I think one of the previous owners must have replaced them with OE, because none of them are blown. I've been riding on them a while too--that's why I can't believe it when everyone says "you'll blow your factory shocks two weeks after you lower your car."
Old Feb 11, 2003 | 04:20 PM
kyle h.'s Avatar
double post? they are stock.
Old Feb 11, 2003 | 04:33 PM
Eggman's Avatar
looks like stock to me. 'SH3' is usually in the part number for OEM ED parts.
Old Feb 11, 2003 | 05:12 PM
T_Rex's Avatar
Default Re: Can you identify these struts? (Eggman)
I guess they're definitely stock. Bummer
Those of you with stock struts and performance springs, what's your opinion of the setup?
[Modified by T~Rex, 6:13 PM 2/11/2003]
Old Feb 11, 2003 | 05:28 PM
IntegCutie82's Avatar
look stock to me too...
Old Feb 11, 2003 | 05:42 PM
JaiDM's Avatar
Default Re: Can you identify these struts? (IntegCutie82)
well performance springs and stock struts is not to bad, as long as its not a big drop. i ran cut springs for a little while with my stock struts and it worked out ok, it was a small drop.
Old Feb 12, 2003 | 08:17 AM
T_Rex's Avatar
Those of you running stock struts with perfromance springs-
I'm mainly wondering how long your stock struts lasted after you put the springs on?
Old Feb 12, 2003 | 08:49 AM
Tyson's Avatar
https://honda-tech.com/zerothread?id=410142
replace em now cuz youll end up having to buy another set of shocks anyway and then youd at least have good stock shocks to go back to stock springs later.
Old Feb 12, 2003 | 11:52 AM
CRX-RX's Avatar
Default Re: Can you identify these struts? (Tyson)
I have/had (back to stock for winter, plus alot of other changes) H&R race springs on when I was road racing at the end of this summer. I had 88 rears with tockico blues, and stock shocks up front. You could tell right off that the rear of the car was awesomely stiff and solid, and you could feel a little more of the stock shock gush up front, not too bad though, and pretty awesome at the track. I pretty much make runs about every weekend that put equivalent loads on my suspension, so I have a fairly aggresive wear rate on these parts, but after about two months is when I really started to notice that they were going down hill fast. The front end started to sway around with less and less control as they started to go bad. They're not blown, but well on their way. I'd guess about another month at my pace before they just crapped out.
Old Feb 15, 2003 | 09:39 AM
T_Rex's Avatar
Default Re: Can you identify these struts? (CRX-RX)
CRX-RX...just re-read your post, and I'm wondering what you meant by "88 rears"?
Old Feb 15, 2003 | 01:00 PM
JOEY F.'s Avatar
Default Re: Can you identify these struts? (T_Rex)
i think he means 88 rear LCAs....cuz theyre different from 89-91. I had the same setup he does...H&R race springs with stock shocks....and boy the stock shocks crapped out in like 3 months of hard autox and "spirited" street driving. But i swapped them out for my Tanabe sustec shocks and its as good as new..even better. I also have the 88 rear LCA's.
Old Feb 15, 2003 | 01:12 PM
T_Rex's Avatar
Default Re: Can you identify these struts? (JOEY F.)
Where'd you buy the Tanabes and how much were they?
Old Feb 15, 2003 | 02:44 PM
I Gotta Question's Avatar
I have blue struts I can't find a name on them anybody know what they could be the chassis has over 200k on it too. So I don't think there stock.Just Curious.
Old Feb 15, 2003 | 06:42 PM
Full-Race Henry's Avatar
Default Re: Can you identify these struts? (89_CRX_HF)
could be tokico or bilstein
Old Feb 16, 2003 | 11:41 AM
Default Re: Can you identify these struts? (EF8_Fan)
Alright thanks for the info. All I know is they ride like a bmw.
RMacSI
Suspension & Brakes
Dec 5, 2012 08:50 PM
RGoose18
Aug 16, 2007 12:20 PM
Libertariat
15
Sep 1, 2006 08:40 PM
T_Rex
Feb 12, 2003 01:23 PM
ekekek
11
Feb 26, 2002 07:07 PM
