need help asap!!!!
Old Feb 11, 2003 | 04:00 PM
SPEED123's Avatar
Default need help asap!!!!
just finish install and i getting an hign idle about 15grand...what is the normal idle 1grand???? how do i correct this? i check all vacuum hoses no luck...what else could it be need help asap
Old Feb 11, 2003 | 04:07 PM
kyle h.'s Avatar
Default Re: need help asap!!!! (SPEED123)
15grand is a very high idle... not very much info. here, but i'll work with what u gave...
check your throttle cable and double check you're vacuum lines.
edit: not sure ur motor and car, but generally idle is somewhere close to 700rmps.
[Modified by kyle h., 1:08 AM 2/12/2003]
Old Feb 11, 2003 | 04:18 PM
altoid's Avatar
Default Re: need help asap!!!! (kyle h.)
t cable adjustment
Old Feb 11, 2003 | 04:59 PM
Neptune's Avatar
Default Re: need help asap!!!! (EE4)
https://honda-tech.com/zerothread?id=411220
There are a ton of idle problems, I think the most common one is dealing with the ecu and vacum lines. Good luck
Old Feb 12, 2003 | 12:03 PM
fathergoose's Avatar
Default Re: need help asap!!!! (Neptune)
check your intake gasket by spraying air intake cleaner around it. If the idle fluctuates, you have found your problem
weaslehunter1
Jan 26, 2015 03:49 PM
luv2boost
Jun 2, 2008 06:33 PM
aws140
Aug 26, 2005 07:51 PM
Creepshow S60
49
May 17, 2005 06:56 PM
headhunter
Aug 18, 2003 08:14 PM
