does the stock B16a air box really restrict air flow that bad?
Old Feb 11, 2003 | 01:52 PM
Civichatch2k's Avatar
Default does the stock B16a air box really restrict air flow that bad?
I have a 99 Si motor in a 99 EK hatch and i have the stock air box. I was just wondering what intake you guys are running, and if they really helped out. The reason that i want to know all this is due to the fact that lastnight i got my *** handed to me by an Si, never happened before. Oh well thats life. thanks.
Old Feb 11, 2003 | 01:58 PM
B_CRUZ!'s Avatar
Default Re: does the stock B16a air box really restrict air flow that bad? (Civichatch2k)
do you know what the si had? he could of possible had cams, a B18C1 block, etc.etc...
On to your intake question...
do you still have the resonator part on? the carbon kevlar spoon one and a k&n drop in is more than enough airflow or you can get a AEM one like everybody else.
[Modified by (BC), 4:07 PM 2/11/2003]
Old Feb 11, 2003 | 03:42 PM
Default Re: does the stock B16a air box really restrict air flow that bad? ((BC))
The Si had intake, header, and exhuast, thats it. Would maybe cutting a little of the box off on the bottom help out on flow. So that kevlar arm help that much?
Old Feb 11, 2003 | 03:44 PM
-Whitey-'s Avatar
just get an aem short ram stick it into your b16a box and use a K&N drop in filter thats the best combo ive used so far aem cai sucks compared to it imo
Old Feb 11, 2003 | 03:45 PM
Plan B's Avatar
Remove the section that is behind the bumper, IMO, that is the most efficient/least noisy/best/cost effective intake solution.
Old Feb 11, 2003 | 03:51 PM
B_CRUZ!'s Avatar
Default Re: does the stock B16a air box really restrict air flow that bad? (FF-Panda)
sounds like a good idea... buy the mandrel bend your self or a generic intake.
Old Feb 11, 2003 | 04:56 PM
euclid's Avatar
if you end up taking out your resonator you can use the piping to make a cold air extension arm for your stock airbox, it will fit in the hole in the bottom of the box, just like it was designed to, and it will look/function like the comptech icebox. i just picked up an itr box that has this and it looks like it will work nice, i havnt had time to instal it yet though.
OneQuickEM1
14
Aug 7, 2010 01:04 AM
machine4321
Jul 10, 2003 08:12 PM
Civichatch2k
Feb 11, 2003 05:11 PM
AMG
Nov 8, 2002 04:54 AM
