power steering problems
Old Feb 11, 2003 | 12:39 PM
bumpin_bass's Avatar
Default power steering problems
Hey I just hooked up a B-series PS pump and it is making mean noises when sitting stationary and turning wheels. I haven't heard the noise while driving, but the engine noise probably over shadows it. There are also tons of bubbles in the fluid. Any ideas of how to fix this? Could I use my old D-series pump with the B-series brackets? Thanks for any info.
Old Feb 11, 2003 | 01:24 PM
92sleepR's Avatar
New User
Default Re: power steering problems (bumpin_bass)
Sounds like the pump is toast. You cant fit the D series on there but a rebuilt B series one isn't too expensive.
Mike
Old Feb 11, 2003 | 03:17 PM
Default Re: power steering problems (92sleepR)
Do you know if I could just by a rebuild kit, how much would that be? Does the d-series pump bolt right up to the B-series brackets?
Thanks
Old Feb 11, 2003 | 03:21 PM
BeavisB16's Avatar
or you could get rid of your p/s and free up some hp.
Old Feb 11, 2003 | 03:40 PM
Default Re: power steering problems (b16Civic93EXsleeper)
Only worth 1-2hp. I have spent the money on it, so I wanna keep it.
Old Feb 11, 2003 | 07:25 PM
b19coupe's Avatar
I had to modify my d-series ps pump to fit the b-series brackets.
Old Feb 11, 2003 | 10:00 PM
Default Re: power steering problems (b19coupe)
What did you do to modify your D-series pump?
Old Feb 12, 2003 | 03:45 AM
b19coupe's Avatar
The lower part of the pump had to be cut where it bolts to the lower bracket in order to make the pump match up with the top and bottom brackets. Last week I removed the whole power steering system in favor of a manual rack and pinion. Actually selling the whole system : https://honda-tech.com/zerothread?id=409993
[Modified by b19coupe, 4:45 AM 2/12/2003]
Old Feb 12, 2003 | 04:49 AM
tpr's Avatar
tpr
Before you do anything rash, how long has it been since you changed out the pump? The air bubbles are typically trapped air that is entrained in the power sterring fluid. After a period of time the air should be purged and the noise should go away. Did you use approved honda power steering fluid? I have been old that it makes a difference. Give it a day or two before changing the pump.
[Modified by tpr, 1:50 PM 2/12/2003]
Old Feb 12, 2003 | 06:30 AM
Default Re: power steering problems (tpr)
Ok I just put the pump in last Sunday, and I have only driven it twice since. I used Honda PS fluid. I will wait and see what it does. Thanks.
Old Feb 22, 2003 | 07:25 PM
Powered by Rowena Galam's Avatar
i did the same thing..but i didn't have to modify it..is it ok to use a D-series pump on a B-series motor?
Old Feb 23, 2003 | 11:21 PM
Default Re: power steering problems (Powered by Rowena Galam)
It should work fine. The mounting bracket would be the only thing different.
xkwzt21
May 14, 2008 05:31 PM
xkwzt21
May 14, 2008 10:06 AM
SiYouLater
Jun 3, 2007 08:37 PM
92CivicLSI
Feb 5, 2005 03:32 PM
HatchBox
Apr 10, 2003 12:19 PM
