most likely a pretty simple question
Old Feb 11, 2003 | 12:31 PM
RiCE On IcE 2's Avatar
Default most likely a pretty simple question
After I drive hard a bit, sometimes I'll get the smell of burnt oil, not like a strong scent but I can smell it none the less, is that normal?.. I'm running mobil 1 and I know it burns a lot but am I supposed to be smelling it? I'm not getting any blue smoke out the exaust as far as I know either.
Old Feb 11, 2003 | 12:32 PM
Reid's Avatar
Global Moderator
Default Re: most likely a pretty simple question (RiCE On IcE 2)
What are your mods?
Are you burning oil?
Old Feb 11, 2003 | 12:33 PM
Default Re: most likely a pretty simple question (Reid)
nada.. stock ITR.... if I'm burning oil it's not an amount that I've noticed on the dip stick.
Old Feb 11, 2003 | 12:34 PM
Reid's Avatar
Global Moderator
If you're not burning oil and your car isn't smoking, don't worry about it.
Old Feb 11, 2003 | 12:37 PM
Chris N's Avatar
This happened when I ran 5w 30 Mobil 1.
I could never get 10W 30 Mobil 1 or ANY other oil of any weight to do what you described, only M1 5w30.
I would not worry about it unless you see smoke.
Old Feb 11, 2003 | 12:41 PM
Default Re: most likely a pretty simple question (Chris N)
yea i think it's 5w-30 mobil one also.. the blue cap? i'm pretty sure thas 5w-30 i should go check
Old Feb 11, 2003 | 12:46 PM
Chris N's Avatar
Yeap, 5w30 M1 is blue cap, 10w is green.
Try 10w30 when it warms up outside (unless you are in the warm weather already), i bet you won't smell what you smell with 5w.
Old Feb 11, 2003 | 12:49 PM
Black Sheep's Avatar
maybe you spilt some oil on your engine or tranny, the heat will fry the oil giving you the smell, mine will smell for a few days with oil changes.
Old Feb 11, 2003 | 01:08 PM
Default Re: most likely a pretty simple question (Black Sheep)
yea I thought that at first but it's been a few weeks since I changed the oil so wutever got on the manifold should be toast by now. Well I'm in Norcal so 10w-30 should be fine eh? hasn't been too cold whats the temperature ratings on liek 10w-30?
Old Feb 11, 2003 | 01:20 PM
ITR 01-0422's Avatar
yeah i'd have to agree with the previous members, just keep checking your oil every now and then to make sure there's oil. i remember when my first car (gsr) burned oil as well i ran with no oil but at least i used synthetic oil. ahah that was a long time ago and i was young and didn't know any better. i don't know how true it is but i hear that ITR's burn a lil oil from time to time but that's when you really get on it...i don't know how hard you drive it but that might be something too but it wouldn't explain the constant oil burning smell. don't know if i helped with your situation but good luck with your oil problem.
Old Feb 11, 2003 | 01:38 PM
J_Edwards's Avatar
Default Re: most likely a pretty simple question (ITR 01-0422)
Do you have an aftermarked intake? If you didn't replace the hose from the breather valve you could be smelling oil from the blow-by caused from driving it hard.
Old Feb 11, 2003 | 02:02 PM
oh no it's not constant, it only occurs after driving it hard then it goes away after a bit
Old Feb 11, 2003 | 02:08 PM
B2FiNiTY's Avatar
Your in CA in general. Don't be afraid of using 10w30.
Old Feb 11, 2003 | 02:56 PM
Bbasso's Avatar
Default Re: most likely a pretty simple question (B2FiNiTY)
Maybe he is smelling the brakes ?
Old Feb 11, 2003 | 03:08 PM
Willard's Avatar
https://honda-tech.com/zerothread?id=232850
betta285
Jul 22, 2008 04:51 PM
cilvia
Feb 6, 2007 05:20 AM
stevescivic
Jun 17, 2006 12:57 PM
T25So
Sep 8, 2004 11:39 AM
vxnine
18
Oct 11, 2003 07:24 PM
