Where does this hose go?
Old Feb 11, 2003 | 12:22 PM
Prevail's Avatar
Default Where does this hose go?
Can anyone tell me? It goes to a sensor on the IM on the old d15 that isn't there on the B16A that is now in the car
Thanks~
Old Feb 11, 2003 | 12:26 PM
4g4me's Avatar
Default Re: Where does this hose go? (ride_with_me)
get a vaccum diagram from a del sol VTEC model. Each hose has a number on it. For the VTEC model del sol, the one with the b16, it will tell you exactly where it goes.
LOoks to me like the purge canister inlet or outlet, should go to the purge valve silenoid, a little accessory on the back of your intake on the driver side.
Old Feb 11, 2003 | 12:30 PM
lonefuzzy79's Avatar
Default Re: Where does this hose go? (4g4me)
it's a small hose so only so many places it can go, it looks like fuel pressure regulator to me ( I think) but it definatly plugs in on the intake manifold somewhere I have to go look at my motor. Remember small hose plugs into small fitting
Old Feb 11, 2003 | 12:33 PM
jdmWONG's Avatar
Default Re: Where does this hose go? (lonefuzzy79)
There is a sensor on your cx motor on the intake manifold that it plugs into, im not sure if its on your new manifold. if its not just take it off the cx motor .
Old Feb 11, 2003 | 12:40 PM
rolow's Avatar
I am with 4g4me it looks like it goes to the Purge control solinoid (PCS)
KeithDigital
Dec 7, 2008 05:06 PM
Frost_1097
Jul 6, 2007 09:38 PM
white94
Mar 22, 2007 08:09 AM
EG6AAARRR!!!
Aug 23, 2004 01:09 PM
frostt3ch
Nov 20, 2003 07:11 PM
