intake manifold confused hose question.
Old 07-06-2007, 07:02 PM
Frost_1097's Avatar
Default intake manifold confused hose question.
I have recently done a engine swap and I think I have finally figured out the last problem. On my D16z6 there is a hose on the bottom of the intake manifold that is hanging down and not connected to anything. I will try to post a picture but it will be later but if anyone knows where this hose may go that would help. or what hose it is?(coolant or vacuum)?
Old 07-06-2007, 07:06 PM
97Ej6mike's Avatar
well if its off the manifold, its most likely a vaccum.
What car did you swap this into?
Old 07-06-2007, 07:10 PM
Frost_1097's Avatar
Default Re: (97Ej6mike)
I took it out off and put it into a del sol. I just needed a new engine fast because my awesome cold air intake sucked up water and snapped one rod and bent two others. If it is a Vaccum hose, should it be connected to anything?
Old 07-06-2007, 07:16 PM
97Ej6mike's Avatar
There are quite a few vaccuum/coolant lines on the manifold. Lemme see if i can find a diagram.
Old 07-06-2007, 07:22 PM
Frost_1097's Avatar
that would be awesome! A diagram would be very helpful!
Old 07-06-2007, 09:38 PM
Frost_1097's Avatar
Default Re: (Frost_1097)
bump up
Yuta
06-24-2019 05:06 PM
DanDaMan559
06-16-2011 11:48 AM
gnccracer18
03-24-2008 06:14 PM
houstondigital
08-29-2005 11:48 AM
Ace00
06-28-2004 06:41 PM
Quick Reply: intake manifold confused hose question.
