What does white mean? Please read <<<<<<<<<<<<<<<<&
Old Feb 11, 2003 | 12:43 AM
BlkGSR's Avatar
Default What does white mean? Please read <<<<<<<<<<<<<<<<&
What does it mean when is see a white residue on the inside of my header?
Old Feb 11, 2003 | 01:33 AM
Anthony K's Avatar
New User
Default Re: What does white mean? Please read <<<<<<<<<<<<<<<&
Are you getting smoke out of the exhaust?
Old Feb 11, 2003 | 02:25 AM
violator462's Avatar
Some curious kid thought that was how people get some 'head.'
[Modified by thabridawg, 11:28 AM 2/11/2003]
Old Feb 11, 2003 | 03:14 PM
BlkGSR's Avatar
nothing noticeable... But i think i get some smoke under heavy throttle.
Old Feb 11, 2003 | 04:05 PM
MooreBoost's Avatar
Moron.....Anyway, someone wrote into a mag about how his entire engine was covered in the same ****. But not just his headers, maybe its coolant? Im actually not sure. Is the residue behin the headers on the block? Is it on the radiator fans?
gmoore
EDIT- Wait a minute, you said INSIDE? Is it actually inside the header? If it is, I have no idea.
[Modified by gmoore379, 1:07 AM 2/12/2003]
Old Feb 11, 2003 | 04:24 PM
au-gsr's Avatar
i gurantee you if you pull off the oil pan you will have a layer of oil on top and antifreeze on th bottom. theonly thing that produces a white residue in the engine upper or lower block is water antifreeze mix. probably have a seal problem.
Old Feb 11, 2003 | 10:53 PM
BlkGSR's Avatar
yes, it is inside the exhaust piping from header to tip. I think i do have a leak (headgasket) since i have 100k+ mi.
Running too rich or lean wouldnt cause this would it?
Thanks
Old Feb 11, 2003 | 11:09 PM
x James Bond x's Avatar
I second that. Happen to me once.
Old Feb 11, 2003 | 11:48 PM
integobsession's Avatar
or a blown headgasket.. but i'm sure you'll know that it's the headgasket...
Old Feb 12, 2003 | 09:17 AM
BlkGSR's Avatar
Is it possible to have a leak from other than the headgasket?
Old Feb 12, 2003 | 09:21 AM
NeoGSR's Avatar
dumbass
i'd bet on that head gasket being the problem....there's really no where else for antifreeze to get inside....coolant burns white which would explain the white residue
EFlovin'
15
Aug 5, 2013 11:16 AM
sir_racer2000
Jan 28, 2007 02:20 PM
mcgee*
11
Feb 22, 2006 07:36 AM
IdotheSHOCKER
Jan 3, 2003 03:20 PM
R-1303
Nov 26, 2002 01:41 AM
